[GRASS5] [bug #882] (grass) Configure errors
Bob Covill bcovill at tekmap.ns.ca
Thu Dec 20 09:28:35 EST 2001
Andreas Lange wrote:
> Hi Andrea,
> Request Tracker wrote:
> > ./configure reports the following error:
> > checking whether to use Tcl/Tk... yes
> > checking for location of Tcl/Tk includes...
> > checking for tcl.h... yes
> > checking for tk.h... no
> > configure: error: *** Unable to locate Tk includes.
> > but tk is installed and tk.h is in /usr/include!!!
> > If I force header location:
> Usually tcl/tk is found. But perhaps there was some incompatible change
> from 8.3.1 (which is running here) to 8.3.3? Or tk.h is only a
> place-holder? No idea here.
> > ./configure --with-tcltk-includes=/usr/include
> > checking for location of Tcl/Tk includes... /usr/include
> > rpm -qi tk reports that Tk 3.3.3 is installed.
> > Then I've done ./configure --without-tcltk and it doesn't find
> > the postgresql includes (they are in /usr/include/pgsql, I have
> > to force that location). I have Mesa 3.4.2 installed but configure
> > says:
> yes, the postgresql includes are in different dirs on different
> platforms/distros.
> > checking whether to use OpenGL... yes
> > checking for location of OpenGL includes...
> > checking for GL/gl.h... yes
> > checking for GL/glu.h... yes
> > checking for location of OpenGL library...
> > checking for glBegin in -lGL... no
> > configure: error: *** Unable to locate OpenGL library.
> > ... REQUIREMENTS says that Mesa 3.x is needed, but this one is
> > not recognized.
> > Umpf, in the end configure does its work with the following parameters:
> What _exactly_ do you have installed?
> I have installed Mesa-devel-3.3-5 and Mesa-3.3-5 rpms (Red Hat 7.0 based
> system).
> > ./configure --without-tcltk --with-postgres-includes=/usr/include/pgsql --without-opengl --without-odbc --without-fftw
> > (odbc and fftw in fact are not installed, but do you expect that they
> > are installed on the average machine? The should be disabled IHMO)
> fftw is needed for several modules. It is a clean build (./configure;
> make; make install) on all systems i encountered so far. Maybe there is
> a rpm file too.
> HTH,
> Andreas
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> url: http://mitglied.tripod.de/AndreasLange
> mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Hello,
I don't know if it is related or not. On my latest build (Solaris 7) I
ran into some configure problems. The TCL / TK options would not build
even though they are installed. When I examined the config.log I found
compile errors related to the linker. I then manually editted configure
and added the -lsocket -lnsl -ldl flags to the TCL and TK lines of
configure. This allowed the test program to build and recognize that TCL
/ TK was installed on my system.
I also ran into the same problem of having to run configure with a whole
lot of things disabled. To build it on my (dated?)  Solaris system I had
to use the following....
./configure -with-postgress=no -with-gd=no -with-odbc=no -with-ddtw=no
-with-blas=no -with-lapack=no -with-freetype=no
I am used to disabling postgress for the Solaris but there seems to be
alot more options that need disabling if packages are not installed. I
am not a configure expert, but is it not possible for configure to
disable the feature if it is not found, rather than exiting with an
error?
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
