[GRASS5] r.in.gdal tiff and adf
Helena hmitaso at unity.ncsu.edu
Thu Dec 20 16:35:55 EST 2001
Thank you for your answers. I have the files imported using other means but if anybody
(Frank?)
would like to look at them they are at
http://skagit.meas.ncsu.edu/~helena/grasswork/grassprobl/
the binary arcgrid is
in the directory lulc
and the tiff file is
c0792_004.TIF
output of tiffinfo is in the file tiffinfo
Markus cannot read it with r.in.gdal either, so there may be a problem.
thank you,
Helena
"Eric G. Miller" wrote:
> On Wed, 19 Dec 2001 13:08:17 -0500, Helena Mitasova <hmitaso at unity.ncsu.edu> wrote:
> > I have finally downloaded gdal and I am trying to run some tests.
> > So far I had the following problems:
> > 1. I tried to import Arcinfo grid binary, but it is not recognized
> > (it is listed as supported with the suffix aig - do I understand it
> > correctly?):
> > ERROR 4: `w001001.adf' not recognised as a supported file format.
> > the coverage has these files:
> > dblbnd.adf  hdr.adf  log  prj.adf  sta.adf  vat.adf  w001001.adf
> > w001001x.adf
> Haven't tried binary grid support ... ?  I usually use GRIDASCII and
> r.in.arc...
> > 2. I have tiff images which can be imported with r.in.tiff but gdal does
> > not like them.
> > These files were created from sid probably on Mac - is there anything
> > that one should do when converting to tiff to make sure it can be
> > imported
> > by r.in.gdal?
> > GRASS:/data/indata/LakeWheeler/Gis/data/color_ir > r.in.gdal
> > c0792_004.TIF out=test
> > ERROR 1: c0792_004.TIF:0: Bad value for "SamplesPerPixel
> Hmm, I'm surprised gdal would barf where r.in.tiff would do okay (the
> opposite is usually true).  I dunno for sure, but is your gdal using
> a static tiff library?  Otherwise, both should be using the same
> libtiff ...?  Boggle?  Do you have tiffinfo installed? Or gdalinfo ?
> If so, what is "their" opinion of these files?
> > any feedback will be appreciated,
> Frank is obviously the best person to ask regarding GDAL...
> Eric G. Miller <egm2 at jps.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
