[GRASS5] February 19, 2001 Cygwin build
Eric G. Miller egm2 at jps.net
Thu Feb 22 03:17:32 EST 2001
On Thu, Feb 22, 2001 at 09:21:03AM +1000, Mike Thomas wrote:
> Hi all,
> I just built from yesterday's CVS source on Win98, using sockets.
> I was wondering if anyone else is getting the following problem - when I try
> to open the HTMLMAP and CELL drivers I get:
> GRASS-GRID > d.mon CELL
> Graphics driver [CELL] started
> Wait for 'READY'
> READY
> ERROR: In SWITCHER.c: G_sock_listen() got error The descriptor is a file,
>        not a socket
> Socket is already in use or not accepting connections.
> Use d.mon to select a monitor
> Problem selecting CELL. Will try once more
I suspect the CygWin port to the 9x series doesn't support unix sockets.
I tried to check at http://sources.redhat.com/cygwin, but the server is
not responding at the moment...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
