[GRASS5] February 19, 2001 Cygwin build
Malcolm Blue
mblue at nb.sympatico.ca
Wed Feb 21 22:30:08 EST 2001
Mike,
From my experience trying to run the XDRIVER on Win98 I suspect your
problems are caused by poor process management with Cygwin/Win98.
XDRIVER and CELL run OK with Cygwin/WinNT, but I was unable to get the
XDRIVER running on Win98 (I didn't try CELL at the time). Since both
use fork(), I suspect they are doing something in that implementation
that doesn't work reliably on Win 98.
When I start the XDRIVER using d.mon start on WinNT, the XDRIVER.exe is
listed in the process list from the ps command. When I tried the same
thing on Win98, it seemed to start the XDRIVER, but then issued some
error messages (IPC version messages). The ps command did not list the
XDRIVER.exe process.
Unfortunately a number of Cygwin API calls work on WinNT that don't work
on Win98. I'm able to run both IPC and socket version of GRASS on WinNT.
Sorry I couldn't give you better news, but I think its a cygwin/Win98
problem.
Malcolm
Mike Thomas wrote:
> Hi all,
> I just built from yesterday's CVS source on Win98, using sockets.
> I was wondering if anyone else is getting the following problem - when I try
> to open the HTMLMAP and CELL drivers I get:
> GRASS-GRID > d.mon CELL
> Graphics driver [CELL] started
> Wait for 'READY'
> READY
> ERROR: In SWITCHER.c: G_sock_listen() got error The descriptor is a file,
> not a socket
> Socket is already in use or not accepting connections.
> Use d.mon to select a monitor
> Problem selecting CELL. Will try once more
> Cheers
> Mike Thomas
> ----- Original Message -----
> From: John Huddleston <jhudd at lamar.colostate.edu>
> To: grass5 <grass5 at geog.uni-hannover.de>
> Sent: Wednesday, 21 February 2001 1:02 PM
> Subject: Re: [GRASS5] February 19, 2001 Cygwin build
>> Eric, (Grass list)
>> OK, will do tomorrow.
>> John
>> From: "Eric G. Miller" <egm2 at jps.net>
>> To: "grass5" <grass5 at geog.uni-hannover.de>
>> Sent: Tuesday, February 20, 2001 6:56 PM
>>> On Tue, Feb 20, 2001 at 12:49:45PM -0700, John Huddleston wrote:
>>>> Markus, (Anyone)
>>>> It was configured --with-ipc
>>>> Do you have a recommendation for configure for Cygwin?
>>> It'd be helpful if you could tell us how/if GRASS works using the
>>> --with-socket variant.
>>> Eric G. Miller <egm2 at jps.net>
>>> If you want to unsubscribe from GRASS Development Team mailing list
> write to:
>>> minordomo at geog.uni-hannover.de with
>>> subject 'unsubscribe grass5'
>> If you want to unsubscribe from GRASS Development Team mailing list write
> to:
> If you want to unsubscribe from GRASS Development Team mailing list write to:
