[GRASS5] One step at a time.
Jeshua Lacock
jeshua at SierraMaps.com
Sun Feb 18 21:47:27 EST 2001
>On Sun, 18 Feb 2001, Malcolm Blue wrote:
> > Check to see if the files /usr/local/grass5/dev/fifo.1a,
> > /usr/local/grass5/dev/fifo.1b, etc. exist and that they are fifo
>files. They
> > should have permissions like prw-rw-rw-.
>Malcolm,
> Nope. /usr/local/grass5/dev is a shell script, not a directory.
> > If these don't exist, you should be able to create them with the
>create_fifos.sh
> > script in /usr/local/grass5/dev. Run it as:
> > ./create_fifos.sh /usr/local/grass5
> See above. There is no create_fifos.sh because there's no directory called
>dev/. It's a shell script file.
Rich, Malcom, et al,
I have reported the same behavior for Beta 11 on Mac OS X.
What I did was
mv dev ../..
mkdir dev
chmod 777 ../../dev
../../dev /usr/local/grass5
That should create the fifios for you.
Yours,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
