[GRASS5] Simplified sites read for several modules
Markus Neteler
neteler at geog.uni-hannover.de
Tue Feb 6 15:53:33 EST 2001
Hi all,
I have updated s.kcv, s.normal, s.probplt, s.sv, s.univar
to use G_readsites() to read sites instead of having individual
readsites.c files with identical functionality.
To test please update:
include/readsites.h
libes/gis/readsites.c
sites/
The other sites modules still have to be updated (volunteers).
Finally all sites modules shall use the API to read in sites
(probably using Eric Miller's G_readsites_xyz() instead of
G_readsites()). Then it will be easier in future to switch over
to a new sites management.
The list can be found in TODO (check for G_readsites_xyz)
I have tested the changes successfully with 2D/3D multiple att sites
files.
Cheers
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
