[GRASS5] Re: [GRASSLIST:1423] r.water.fea tutorial
Markus Neteler neteler at geog.uni-hannover.de
Tue Feb 6 03:56:53 EST 2001
On Mon, Feb 05, 2001 at 08:15:24PM +0100, Cristiano G. wrote:
> Hi all,
> I have downloaded the tutorial of r.water.fea from
> http://www.geog.uni-hannover.de/grass/gdp/raster/r_water_fea/ but I can
> not visualize anything when open it in kghostview (kde ghostview). It
> seems that there are write nothing in them... only blank pages. Can
> someone send me this tutorial or indicate others sites where i can
> download information about r.water.fea different from html manpage?
> Many thanks in advance.
> Cristiano G.
Ciao Cristiano,
here it comes fine with "ghostview" and "gv". It seems to be a bug
with kghostview.
You can also generate PDF from it with
ps2pdf
which is distributed with ghostscript (probably already on your machine).
Then
acroread
will work.
Hope this helps
 Markus Neteler
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
