[GRASS5] nviz-bug
Markus Neteler
neteler at geog.uni-hannover.de
Sun Feb 4 06:18:04 EST 2001
Hi all,
On Sun, Feb 04, 2001 at 09:18:53AM +0100, Jaro Hofierka wrote:
> Helena Mitasova - staff wrote:
> > Bill and Jaro,
> > (I am sending this to developers list too, in case that
> > somebody would like to look at it)
> > which version of GRASS do you have ?
> > It appears that the nviz bug is in beta8 and
> > later versions (Justin tried it on SGi
> > and Bob reports it too), but not in the older versions.
> Hela,
> I have never encountered a such problem in my grass5.0beta6. I am
> still using early versions of NVIZ adopted for Mesa (nviz2.1, nviz2.2).
> I displayed your test data using various positions, zooms, exagg, etc.
> without any problem.
> We should track down the change in the NVIZ code which caused this bug...
> Maybe Markus could send us a complete list of bugfixes and changes made in the NVIZ
> for each relevant version of GRASS?
sure.
Find attached the log from 29. Dec. 2000 up to today.
This are the tags:
o GRASS 5 beta 10: tagged as "release_grass5beta10_7_december_2000"
o GRASS 5 beta 9: tagged as "release_grass5beta9_6_december_2000"
o GRASS 5 beta 8: tagged as "release_grass5beta8_26_july_2000"
o GRASS 5 beta 7: tagged as "release_grass5beta7_20_april_2000"
o GRASS 5 beta 6: tagged as "release_grass5beta6_16_feb_2000"
So if beta6 was o.k., the bug can be traced within CVS as CVS was started
in 1999.
To check out an older version using above tags is described here:
http://www.geog.uni-hannover.de/grass/grasscvs.html
Thanks for looking into this.
Markus
(BTW: The Italian conference was nice, many new ideas. See grass5 list
later.)
2001-01-29 13:47 markus
* src/nviz_init.c: changed version string to auto-update
2001-01-23 17:27 markus
* BUGS_TODO: 1.3 fixed
2001-01-12 09:49 justin
* src/query_postgr.c: reverted back due to some strange error in
CVS
2001-01-12 09:44 justin
* scripts/panel_query.tcl: reverted back due to some strange error
in CVS
2001-01-12 09:17 justin
* scripts/panel_query.tcl, src/query_postgr.c: Added site.h since
it was removed from gis.h
2000-12-06 07:29 cho
* FreeBSD.specific, Gmakefile, scripts/nviz2.2,
scripts/structlib.tcl, src/query_postgr.c: applied GRASS_TCLSH and
GRASS_WISH removed OS specific script
2000-12-05 11:14 cho
* scripts/nviz2.2: nviz2.2 just reverted
2000-12-05 10:45 cho
* scripts/nviz2.2: added check for GRASS_TCLSH env var to use
non-standard tclsh names.
2000-11-30 18:53 cho
* src/Gmakefile.in: added PQLIBPATH
2000-11-29 09:19 markus
* scripts/structlib.tcl: replaced hard-coded wish by new wish
fragment
2000-11-26 14:08 markus
* src/Gmakefile.in: split TCLTKLIBS into TCLTKLIBPATH and TCLTKLIBS
2000-11-25 09:20 markus
* scripts/widgets.tcl: Bob Covill: fixed small exception problem
with the NVIZ updates while trying different parameter combinations
2000-11-24 02:39 eric
* src/runInfxQry.c: Let PG_HOST be NULL
2000-11-23 20:44 markus
* NVIZ2.2-UPDATE.txt: added update notes from Bob
2000-11-23 13:18 markus
* scripts/panel_main.tcl, scripts/panel_site.tcl,
scripts/panel_vect.tcl, scripts/panel_vol.tcl, scripts/widgets.tcl,
src/draw.c, src/init_commands.c: Bob Covill: added auto-redraw and
auto-selection for vector and sites maps
2000-11-23 07:18 cho
* scripts/nviz_init.tcl: I experienced "bus error" bug whenever I
ran "nviz2.2 elev=map" after "g.region rast=map". No error
occurred if i used "d.zoom" to set smaller region than full region.
I don't know why Nset_focus_map is commented. Anyway, bug
disappeared after this line uncommented.
2000-11-08 20:02 cho
* scripts/fileBrowser.tcl: Image dump dir changed to images from
rgb.
You can dump all images in GISDBASE/LOCATION_NAME/MAPSET/images
dir, if it exists. Otherwise you'll browse your home directory
first.
Unfortunately, whenever you dump images you always browse images or
home dir first by limits of tcl script call.
2000-11-02 16:50 cho
* Gmakefile: bugfixed Sorry for inconvenience.
2000-11-01 18:40 markus
* TOGL/: togl.c, togl.h: updated CVS-Id style
2000-10-31 17:15 cho
* Gmakefile, FreeBSD.specific: updated to rename tclsh to tclsh?.?
on FreeBSD
2000-10-28 17:13 markus
* scripts/nviz2.2: Bob Covill: parameter bugfix
2000-10-28 15:36 markus
* nviz.man.1: html only
2000-10-28 15:30 markus
* TODO.linux: inserted in TODO
* TODO: updated
2000-10-25 15:31 markus
* scripts/nviz2.2: Bob Covill <bcovill at tekmap.ns.ca>: new startup
script based on tcl
2000-10-25 15:30 markus
* Gmakefile, src/Gmakefile.in: NVWISH2.2 stored in etc/nviz2.2/ now
to avoid confusion with front.end
2000-10-25 15:10 markus
* scripts/tk.tcl: removed old file
2000-10-20 09:58 markus
* TOGL/README: added comment
2000-10-20 09:15 markus
* BUGS_TODO: Helena: updated
2000-10-20 07:20 cho
* README, README.linux: adapted comments about configure
2000-10-19 07:52 eric
* src/tkUnixPort.h: make that #if ...
2000-10-19 07:40 eric
* src/tkUnixPort.h: Added '#ifdef (TCL_MINOR_VERSION) < 2' wrapper
around 'panic()' declaration. Now NVIZ compiles and runs after 2+
weeks of no NVIZ. *** Hope this doesn't cause breakage for others
2000-10-18 20:13 markus
* Gmakefile: removed gmakelinks5 call as unnecessary now
2000-10-17 10:28 markus
* src/Gmakefile: removed as is will be built while compiling
2000-10-16 18:15 markus
* src/: togl.h, tkInt8.3.h, tkIntDecls8.3.h: Bob Covill
<bcovill at tekmap.ns.ca>: added tcl8.3 sensivity
2000-10-16 18:14 markus
* src/: tkInt.h, tkInt8.0.h: renamed from tkInt.h to tkInt8.0.h
2000-10-11 20:27 markus
* scripts/nviz.man.1: obsolete
2000-10-11 16:02 markus
* src/: Gmakefile, Gmakefile.in: removed GISLIB from EXTRA_CFLAGS
as causing problems
2000-10-11 15:38 markus
* src/Gmakefile.in: corrected DSPINC
2000-10-11 12:29 cho
* src/: Gmakefile, Gmakefile.in: changed preconfig to preconfigure
2000-10-11 12:00 cho
* Gmakefile: added warning
2000-10-11 11:45 markus
* BUGS_TODO: Helena: added
2000-10-11 11:30 cho
* Gmakefile, preconfigure: My make doesn't work if TARGET and SHELL
name are equal. Corrected this bug and output.
2000-10-11 10:48 markus
* README: updated install rules
2000-10-11 10:35 markus
* Gmakefile: corrected precofigure name
* preconfigure: was premake
2000-10-11 10:34 markus
* premake: renamed to preconfigure
2000-10-11 09:32 cho
* preconfig, premake: renamed preconfig to premake
2000-10-11 09:27 cho
* preconfig: improved preconfig
2000-10-11 09:15 cho
* preconfig: you can override global setting for PostgreSQL.
env PGSQL=NO gmake5
This makes postgresql unsupported NVIZ2.2.
And if global setting for PostgreSQL is disabled then
env PGSQL=YES gmake5
will complain about PostgreSQL support enabled.
2000-10-11 08:52 cho
* Gmakefile, src/Gmakefile, src/Gmakefile.in: corrected comments
2000-10-11 08:46 cho
* Gmakefile, Gmakefile.in, configure, preconfig, src/Gmakefile,
src/Gmakefile.in: removed configure and use src/CMD/head/head file
to support PostgreSQL
2000-10-11 07:27 cho
* configure: fixed path for removal
2000-10-10 09:23 markus
* configure, src/Gmakefile, src/Gmakefile.in: re-added PQLIB/sed
stuff
2000-10-06 14:19 markus
* src/: Gmakefile, Gmakefile.in: added ODBC sql.h search, adjusted
-I for tcl/tk and OGL includes
2000-10-04 20:12 cho
* src/: Gmakefile, Gmakefile.in: added XCFLAGS, TCLINCDIR and
TKINCDIR
2000-10-04 17:11 markus
* src/Gmakefile.in, Gmakefile, configure, src/Gmakefile: added
search for PostgreSQL libs and includes
2000-10-04 14:50 markus
* Gmakefile, Gmakefile.in, configure, src/Gmakefile,
src/Gmakefile.in: removed local tcl/tk library search, replaced by
GRASS-system variables (src/CMD/head/head)
2000-10-02 17:59 markus
* Gmakefile, src/Gmakefile: cosmetics
2000-10-02 17:57 markus
* scripts/nviz2.2_script, scripts/panel_animation.tcl,
scripts/panel_kanimator.tcl, scripts/widgets.tcl, src/Gmakefile.in,
src/anim_support.c, src/init_commands.c: Bob Covill
<bcovill at tekmap.ns.ca>: nviz update to create a new NVIZ program
entitled Nwrite_tif. three updated TCL scripts, that incorporate
the three image formats. The image dump button now goes to cascade
menu where the user can select to dump to an RGB, PPM, or TIFF. In
the animation menus, I added radiobuttons to the final dump menus.
When setting base name for dump files, the file type can also be
set. The default format for the animations is set to PPM.
2000-09-25 14:07 markus
scripts/panel_kanimator.tcl, src/Gmakefile, src/anim_support.c,
src/init_commands.c, Gmakefile.in: Bob Covill: patched to write PPM
format
2000-09-25 14:02 markus
* src/Gmakefile.in: added missing lib path
2000-09-07 16:37 bernhard
* LICENCE.txt: Changed License of NVIZ to GPL, as requested and
authorized by Bill Brown in a Mail to the grass5 developers list
from Date: Tue, 5 Sep 2000 09:44:29 -0500 (CDT) Message-Id:
<200009051444.JAA44379 at ziggy.gis.uiuc.edu>
2000-09-05 11:14 markus
* configure, src/Gmakefile.in: libpg disabled if PostgreSQL not
wanted
2000-08-07 19:44 bernhard
* configure: Added /usr/X11R6/include/GL to search path for nviz
configure. (Mesa 3.2 for Redhat6.2 installed it there.)
2000-07-26 23:16 markus
* src/query_postgr_dummy.c: removed digit.h
2000-07-26 15:07 markus
* src/: query_postgr.c, query_postgr_orig.c: corrected vector
header
2000-07-14 12:10 bill
* src/Gmakefile: [no log message]
2000-07-13 15:17 markus
* src/: query_postgr.c, getCat.c: removed dig*.h as Vect.h is
sufficient now
2000-07-12 21:30 cho
* scripts/: fileBrowser.tcl, panel_animation.tcl,
panel_kanimator.tcl: Save box browses
GISDBASE/LOCATION_NAME/MAPSET/rgb first. If this does not exist,
browse HOME directory then '.'. This method cannot save changed
directory after closing dialog box.
2000-07-03 16:07 markus
* scripts/nviz2.2: adjusted parameter management
2000-06-22 09:35 cho
* scripts/: panel_animation.tcl, panel_kanimator.tcl: Huidae Cho
<hdcho at geni.knu.ac.kr>: GISDBASE/LOCATION_NAME/MAPSET/rgb applied
2000-06-22 08:50 cho
* scripts/fileBrowser.tcl: Huidae Cho <hdcho at geni.knu.ac.kr>:
GISDBASE/LOCATION_NAME/MAPSET/rgb directory can be used to store
rgb files if this directory exists.
2000-06-12 16:06 cho
* configure, src/Gmakefile.in: Huidae Cho <hdcho at geni.knu.ac.kr>:
added FreeBSD sensivity: -ldl
2000-05-26 16:04 markus
* configure, src/tkUnixPort.h: Huidae Cho <hdcho at geni.knu.ac.kr>:
2000-05-05 16:22 markus
* configure: Andreas Lange: /usr/freeware/include
/usr/freeware/lib32 added (SGI)
2000-04-03 18:09 markus
* scripts/panel_query_orig.tcl, scripts/panel_query_pg.tcl,
configure: Alex Shevlakov: patch to manage PostgreSQL support in
menus
2000-03-22 21:57 markus
* scripts/nviz2.2: changed starting ':' to '#!/bin/sh'
2000-03-22 21:42 markus
* README.mesa31: by Andreas Lange
2000-03-22 21:40 markus
* README.mesa30: was README.mesa3d
* README.mesa3d: renamed to README.mesa30
2000-03-09 18:14 markus
* scripts/nviz2.2: changed '#!' to ':'
2000-03-06 18:26 markus
* README.postgresql: added URL
2000-03-06 18:16 markus
* configure, src/Gmakefile, src/Gmakefile.in, src/buildInfxQry.c,
src/getCat.c, src/infx.h, src/init_commands.c, src/openvect.c,
src/position.c, src/query_postgr.c, src/query_postgr_dummy.c,
src/query_postgr_orig.c, src/runInfxQry.c, README.postgresql,
scripts/panel_query.tcl, Gmakefile: Alex Shevlakov: added new
fields in WHATS HERE menu for GRASS/PostgreSQL interface
2000-03-06 10:14 markus
* TODO: Philip Warner/Markus Neteler: update to relative paths
implemented
2000-03-06 10:13 markus
* relative_path.txt: removed obsolete file
2000-03-06 10:12 markus
* Gmakefile.in: no locate nviz2.2 dir required any more
2000-03-06 10:07 markus
* scripts/: config.tcl.in, nviz.in, script_file_tools.in,
script_get_line.in, script_play.in, script_tools.in: Philip
Warner/Markus Neteler: removed because of update to relative paths
2000-03-06 10:06 markus
* scripts/: attPopup.tcl, config.tcl, mapBrowser.tcl, nviz2.2,
nviz2.2_script, panel_vol.tcl, script_file_tools, script_get_line,
script_play, script_support.tcl, script_tools, tclIndex: Philip
Warner/Markus Neteler: updated to relative paths
2000-03-06 10:02 markus
* Gmakefile.in, configure, Gmakefile, src/Gmakefile.in,
src/nviz_init.c, src/Gmakefile: Philip Warner/Markus Neteler:
2000-03-02 18:40 markus
* scripts/oglnviz.tmp: removed obsolete file
2000-02-29 16:01 markus
* src/: Gmakefile, nvizAppInit.c, nvizMain.c: Philip Warner
2000-02-29 16:00 markus
* src/: tkAppInit.c, tkBind.c, tkMain.c, tkSend.c, tkSend_old.c,
tkSpecial_Wait.c, tkUnixInt.h: Philip Warner: obviously not
required any more
2000-02-29 15:43 markus
* src/: map_obj.c, init_commands.c: Philip Warner
(pjw at rhyme.com.au): bugfix on NVIZ segmentation fault
2000-02-29 15:38 markus
* src/Gmakefile.in: Philip Warner (pjw at rhyme.com.au): Handle Tcl/Tk
shared libs (remove tkBind.c), Remove tk*.c as far as possible, Use
idle handler instead of SpecialWait
2000-02-22 20:19 markus
* src/tkInt.h: added definition for Tk_SendCmd
2000-02-22 20:02 markus
* src/Gmakefile.in: added XEXTRALIBS for Solaris2.6
2000-02-22 19:21 markus
* src/Gmakefile.in: added XDRLIB
2000-02-06 16:00 markus
* src/: anim_support.c, change_view.c, cutplane_obj.c, draw.c,
exag.c, glwrappers.c, init_commands.c, interface.h, label.c,
lights.c, misc.c, nviz_init.c, position.c, quick_draw.c,
script_support.c, tkAppInit.c, tkBind.c, tkMain.c, tkSend.c,
tkSend_old.c, tkSpecial_Wait.c, togl.h, togl_cb.c: Bill Hughes:
update prototyping and 'return' fixing
2000-02-06 15:47 markus
* configure: Bill Hughes: update prototyping and 'return' fixing
2000-01-12 09:52 markus
* src/tkInt.h: commented line 46: Tk_PostscriptInfo
2000-01-06 16:49 markus
* Gmakefile.in, Gmakefile.in: Markus: update to ignore CVS/
directories when 'cp' to prevent errors
2000-01-03 18:28 markus
* src/Gmakefile: John: updated Gmakefiles for Cygnus (mv command)
1999-12-29 16:12 markus
* Gmakefile, Gmakefile.in, LICENCE.txt, NVIZ2.2-UPDATE.txt, README,
README.linux, README.mesa3d, Readme_nviz.1st, TESTING, TODO,
TODO.linux, configure, nviz.man.1, relative_path.txt, TOGL/LICENSE,
TOGL/README, TOGL/Togl.html, TOGL/tkInt.h, TOGL/tkInt4.0.h,
TOGL/tkInt4.1.h, TOGL/tkInt8.0.h, TOGL/tmp, TOGL/togl.c,
TOGL/togl.h, TOGL/apps/Makefile, TOGL/apps/ben.rgb,
TOGL/apps/double.c, TOGL/apps/double.tcl, TOGL/apps/image.c,
TOGL/apps/image.h, TOGL/apps/index.c, TOGL/apps/index.tcl,
TOGL/apps/texture.c, TOGL/apps/texture.tcl,
nviz2.2/scripts/nviz2.2, nviz2.2/scripts/script_file_tools,
nviz2.2/scripts/script_get_line, nviz2.2/scripts/script_play,
nviz2.2/scripts/script_tools, TOGL/apps/tkInt.h,
TOGL/apps/tkInt4.0.h, TOGL/apps/tkInt4.1.h, TOGL/apps/togl.h,
TOGL/apps/tree2.rgba, bitmaps/down, bitmaps/left, bitmaps/right,
bitmaps/slow_left, bitmaps/slow_right, bitmaps/stop, bitmaps/trash,
bitmaps/up, scripts/ChangeLog, scripts/assoc.tcl,
scripts/attPopup.tcl, scripts/colorPopup.tcl,
scripts/config.tcl.in, scripts/cross.listing,
scripts/cutplane_channels.tcl, scripts/extra_bindings.tcl,
scripts/fileBrowser.tcl, scripts/filemapBrowser.tcl,
scripts/mapBrowser.tcl, scripts/multimapBrowser.tcl,
scripts/nviz.in, scripts/nviz.man.1, scripts/nviz_init.tcl,
scripts/oglnviz.tmp, scripts/panelIndex,
scripts/panel_animation.tcl, scripts/panel_color.tcl,
scripts/panel_cutplane.tcl, scripts/panel_kanimator.tcl,
scripts/panel_label.tcl, scripts/panel_lights.tcl,
scripts/panel_main.tcl, scripts/panel_mkdspf.tcl,
scripts/panel_query.tcl, scripts/panel_scale.tcl,
scripts/panel_sdiff.tcl, scripts/panel_site.tcl,
scripts/panel_surf.tcl, scripts/panel_tst.tcl,
scripts/position_procs.tcl, scripts/queue.tcl,
scripts/script_file_tools, scripts/script_file_tools.in,
scripts/script_get_line, scripts/script_get_line.in,
scripts/script_play, scripts/script_play.in,
scripts/script_support.tcl, scripts/script_tools,
scripts/script_tools.in, scripts/send_support.tcl,
scripts/structlib.tcl, scripts/tclIndex, scripts/test.fields,
scripts/test.script, scripts/test.state, scripts/tk.tcl,
scripts/unique.tcl, scripts/widgets.tcl,
scripts/wirecolorPopup.tcl, src/ChangeLog, src/Gmakefile,
src/Gmakefile.in, src/TODO, src/TOGL_LICENSE, src/anim_support.c,
src/change_view.c, src/coldefs.h, src/cutplane_obj.c, src/draw.c,
src/exag.c, src/glwrappers.c, src/init_commands.c, src/interface.h,
src/interface_old.h, src/ks_names.h, src/label.c, src/lights.c,
src/tkInt.h, src/map_obj.c, src/misc.c, src/mkdspf_calc_linefax.c,
src/mkdspf_fill_cfax.c, src/mkdspf_init_file.c,
src/mkdspf_iso_surface.c, src/mkdspf_main.c, src/nviz_init.c,
src/position.c, src/quick_draw.c, src/script_support.c,
src/tclcommands, src/tkAppInit.c, src/tkBind.c, src/tkMain.c,
src/tkPort.h, src/tkSend.c, src/tkSend_old.c, src/tkSpecial_Wait.c,
src/tkUnixInt.h, src/tkUnixPort.h, src/tmp, src/togl.c, src/togl.h,
src/togl_cb.c, src/vect.c, src/viz.h, src/compat/license.terms,
src/compat/limits.h, src/compat/stdlib.h, src/compat/unistd.h:
Initial revision
initial CVS import
