[GRASS5] Re: grass5.11 pre beta
Markus Neteler
neteler at geog.uni-hannover.de
Sun Jan 28 05:38:20 EST 2001
Richard,
I have bounced your mail to the developers list:
http://www.geog.uni-hannover.de/grass/grassdevel.html
Please subscribe as we discuss such issues there.
On Sat, Jan 27, 2001 at 05:40:51PM -0700, Richard Christofferson wrote:
> Well! in setting up grass5.11, I was under the impression that
> the unisys patented gif algorithm did not affect my raster files
> as they reside in a cell directory, such as:
> /local/grassdata/lovenia/PERMANENT/cell
> So I did not run the fp_uncompress.sh on it.
That's correct.
Note: There is r.lwz2z now which makes the conversio much more easy:
http://www.geog.uni-hannover.de/grass/announces/announce_lzw_removal.html
(see at bottom)
> The problem is I cant get grass5.11 to show the raster images.
> The other versions of Grass I have (grass5.8) work fine, but I'm
> having bad problems with my monitor.. d.rast fails and then it seems
> that grass loses contact with the monitor and I have to kill it by a
> running kill on the monitors pid.
That's strange. In fact we have been facing some problems here which
are fixed now. But I don't know if they affect the pre1-release.
I will put out src_pre2 today to be sure.
> Feeling much chastened I ran the uncompress and recompress scripts on
> all my locations but that did not seem to help matters. Things remain
> much the same as they were.
> I removed the grass5.11 home dir and reinstalled after the recompression
> but that also did not help.
> So essentially I'm not sure if this is an LZW problem or some other one.
> And if it is an LZW related, issue what is the fix needed, after
> installing without running the compression scripts?
Please try once again with r.lzw2z. It should tell you everything.
> This is a non production machine so I'm not too worried about what I
> do to it.
That's good!
> Well thats that! please tell me if there is another forum for replying
> on pre-beta testing as I'm unsure as to how to proceed..
I'll cc this to "grass5" as well. Talk to you there.
Thanks for your notes,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
