[GRASS5] Bad Fifo! - Mac OS X
Jeshua Lacock
jeshua at SierraMaps.com
Fri Jan 26 20:09:31 EST 2001
On Friday, January 26, 2001, at 04:34 PM, Malcolm Blue wrote:
> Please see the messages related to XDRIVER problems on the list. These
> problems were caused by an inadvertent mix of FIFO and IPC messaging in
> the grass libraries and the XDRIVER and the file types in the dev
> directory.
> The XDRIVER code has been reinstated, so you should update the
> src/display/devices/XDRIVER directory. After that it should work for
> you.
Hi Malcolm,
I just updated and compiled, and I get the same fifo error.
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
