[GRASS5] r.in.gdal
Fri Jan 19 16:28:13 EST 2001
Markus Neteler wrote:
> > I have updated r.in.gdal in CVS to first search in $GISBASE/lib for a
> > libgdal.1.1.so file, and done a simple test.
> Yep! It is detected.
Excellent!
> Frank, just interested: do you *plan* to add HDF support? Otherwise
> we would have to re-activate the HDF3.2-r.[in|out].hdf modules which
> might need heavy updating.
I hadn't been expecting to do it within the next few weeks.  I presume
you mean HDF EOS support, not just regular HDF, right?  If you can patch
up the existing HDF support fairly easily then you should do that.  If
it needs a large chunk of work, then come back to me and I can take a
crack at doing it within GDAL instead.
> Thanks for providing GDAL! Of course I will add it to the Linux binaries
> as you requested. Only a version problem with libstdc++-libc6.2-2.so.3
> may occur (here I had a slightly older version).
Damn.  I was afraid of this.  Perhaps we should push ahead to having
$GISBASE/lib added to the LD_LIBRARY_PATH within the GRASS environment
before the next beta, and putting the C++ runtime library there.
Alternatively, if anyone knows an easy way for me to link it in statically
I can try to fix up the shared library.
Best regards,
light and sound - activate the windows | http://pobox.com/~warmerda
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
