[GRASS5] r.in.gdal
Markus Neteler
neteler at geog.uni-hannover.de
Sat Jan 20 08:43:44 EST 2001
On Fri, Jan 19, 2001 at 04:28:13PM -0500, Frank Warmerdam wrote:
> Markus Neteler wrote:
> > > I have updated r.in.gdal in CVS to first search in $GISBASE/lib for a
> > > libgdal.1.1.so file, and done a simple test.
> > Yep! It is detected.
> Excellent!
> > Frank, just interested: do you *plan* to add HDF support? Otherwise
> > we would have to re-activate the HDF3.2-r.[in|out].hdf modules which
> > might need heavy updating.
> I hadn't been expecting to do it within the next few weeks. I presume
> you mean HDF EOS support, not just regular HDF, right? If you can patch
> up the existing HDF support fairly easily then you should do that. If
> it needs a large chunk of work, then come back to me and I can take a
> crack at doing it within GDAL instead.
O.k., so we postpone it slightly. Perhaps it is not too difficult to
update the existing GRASS modules.
> > Thanks for providing GDAL! Of course I will add it to the Linux binaries
> > as you requested. Only a version problem with libstdc++-libc6.2-2.so.3
> > may occur (here I had a slightly older version).
> Damn. I was afraid of this. Perhaps we should push ahead to having
> $GISBASE/lib added to the LD_LIBRARY_PATH within the GRASS environment
> before the next beta, and putting the C++ runtime library there.
This sounds the best at time. Any idea how to do that? I guess
it is to be done in GISBASE/etc/Init.sh (hi Justin).
> Alternatively, if anyone knows an easy way for me to link it in statically
> I can try to fix up the shared library.
> Best regards,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
