[GRASS5] Releasing GRASS 5.0.0final?
Markus Neteler neteler at geog.uni-hannover.de
Thu Jul 19 09:49:40 EDT 2001
Hi Andreas,
On Tue, Jul 17, 2001 at 03:17:42PM +0200, Andreas Lange wrote:
> Hi all,
> i remember only two things that need to be addressed before the final
> release:
> - add a warning note that r|v|s.proj do not perform datum shifting. Must
> be added to the man/html page and could be added as a output of the
> modules.
> Think that some warnings/recommendations should be put somewhere central
> on the map datum support in grass too. I have currently no CVS access,
> so i can not do this.
I have added hints in module descripton (-help) and HTML pages.
> - check that the problem with the gcc compiler and include paths on IRIX
> and Solaris is solved (can't remember this).
No idea about this...
On Solaris2.6 it compiles well.
Regards
 Markus
