[GRASS5] r.proj doesn't seem to be working properly
Rich Shepard rshepard at appl-ecosys.com
Wed Jul 25 18:34:42 EDT 2001
On Wed, 25 Jul 2001, Rich Shepard wrote:
> GRASS:/mnt/usr4/projects/nevada/coeur > r.proj input=rochester-dem
> location=/mnt/usr4/projects/temp/ output=rochester-dem mapset=PERMANENT
> method=cubic
> ERROR: Mapset [PERMANENT] in input location [/mnt/usr4/projects/temp/] -
>        not found
  As a follow up to my message:
  When I exit GRASS, re-start it and specify temp/PERMANENT as the location
and mapset, I can list and display the map. So, d.rast recognizes the
PERMANENT mapset, but r.proj appears not to.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
                 Making environmentally-responsible mining happen.
