[GRASS5] Darwin Pre1 NVIZ
    Jeshua Lacock
    jeshua at SierraMaps.com
    Tue Jun  5 17:22:26 EDT 2001
On Tuesday, June 5, 2001, at 03:07 AM, Glynn Clements wrote:
> #openGL files for NVIZ/r3.showdspf
> OPENGLINC           =  -I/usr/include -I/usr/X11R6/include
> OPENGLwINC          =  -I/usr/include -I/usr/X11R6/include
> OPENGLLIB           =  -L/usr/lib -L/usr/local/lib -L/usr/lib/X11
> -L/usr/X11R6/lib -lGL
> OPENGLULIB          = -lGLU
> LGLWM               = -lGLw
> OPENGL32            =
> What did configure have to say? Is there anything relevant in
> config.log? A successful run will look something like:
Thanks Glynn!
ALL-RIGHT!!!
NVIZ, is now built for Mac OS X!
The entry in my header was blank for OPENGLwINC, OPENGLULIB and LGLWM,
after I filled them in, boom!  We have NVIZ!
Distrubution question: After Grass is built, does NVIZ require Mesa to
be installed on the machine?
Configure did complain about not finding certain GL headers/libs...
Following is the relevant config.log output:
gluBeginCurve()
; return 0; }
configure:4310: checking for GLwDrawingAreaMakeCurrent in -lGLw
configure:4329: gcc -o conftest -O3     -L/usr/lib -L/usr/local/lib
-L/usr/X11R6/lib -L/usr/X11r6/lib   -L/usr/X11R6/lib/X11 -lXt -lXm
conftest.c -lGLw   1>&5
/usr/bin/ld: can't locate file for: -lXm
configure: failed program was:
#line 4318 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error.  */
/* We use char because int might match the return type of a gcc2
     builtin and then its argument prototype would still apply.  */
char GLwDrawingAreaMakeCurrent();
int main() {
; return 0; }
configure:4350: checking for GLwCreateMDrawingArea in -lGLwM
configure:4369: gcc -o conftest -O3     -L/usr/lib -L/usr/local/lib
conftest.c -lGLwM   1>&5
#line 4358 "configure"
char GLwCreateMDrawingArea();
int main() {
; return 0; }
Thanks again,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
