[GRASS5] Re: [bug #751] (grass) Automatic select of monitor
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon Jun 11 03:21:52 EDT 2001
Hi Glynn
Glynn Clements wrote:
> Request Tracker wrote:
> > When using tcltkgrass with a saved configuration, a monitor opens
> > automatically. However, occaisionaly, it is not selected and I have
> > to select it manually. Perhaps the wait for socket connection is
> > not long enough.
> I don't know if this is related or not, but looking into this made me
> realise that one of my planned changes was never implemented.
> I've now changed the driver startup so that it doesn't fork() until
> after listen() is called (in fact, immediately before the main loop).
> This should completely eliminate any possibility of race conditions;
> the socket will be in the LISTEN state before mon.start exits.
OK, I've updated my sources and tried running tcltkgrass about 10 times
and I haven't seen the problem yet. Perhaps your change fixed this
problem.
Thanks for the fix. I'll mark this resolved on RT.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
