[GRASS5] nviz crashing in pre1
Bob Covill
bcovill at tekmap.ns.ca
Tue Jun 12 12:31:06 EDT 2001
Markus Neteler wrote:
> On Tue, Jun 05, 2001 at 02:53:22PM -0400, Helena Mitasova wrote:
> > Has anybody tested nviz in 5.0pre1? It has a strange behavior - if I
> > start it with -x flag it runs fine. If I start it with -q or a given
> > elevation file it crashes everything and logs me out. However, -q and
> > elevation
> > runs OK if nviz was run with -x flag first. So it seems that -x option
> > sets something which is missing
> > in the other options. Or am I missing something here? I am running it
> > with RedHat 7.1
> > I am not sure whether this is a bug or I don't have something set up
> > properly.
> Helena,
> here it crashes, too. AARGH!! Recently it was o.k.
> - If I start without maps, it opens.
> - If I start with a raster map, it crashes (seg.fault).
> - If I start with a raster map and "-q" it opens but doesn't display
> anything
> - If I start with a raster map and "-x" it opens and works.
> Bob, do you have any ideas?
> Markus
Markus,
I am hoping to install RedHat 7.1 later this week, so I should be able
to test NVIZ then.
As far as the above flags..., the "-q" option is the quickstart option,
which ignores any supplied parameters and simply starts. The "-x" is
essentially the same (?) as the quickstart option except the "Please
Wait" window does not come up. As far as I can tell that is the only
diffeence between "-q" and "-x".
A good test would be to try loading a raster from nviz after starting
with "-q" or "-x". Presumably it would still crash??
A copy of the standard output from the crash might help.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
