[GRASS5] nviz crashing in pre1
Bob Covill bcovill at tekmap.ns.ca
Tue Jun 12 13:17:12 EDT 2001
Markus Neteler wrote:
> Thanks for your quick response, Bob.
> Aha "funny":
> - it crashes if the map region contains only NULL data values (should
>   gracefully exit here). Above happened when I was (accidentally) working
>   in a NULL data area in "nations" map.
> Maybe that's another bug. Helena, are you sure that your map contains data
> when crashing with NVIZ?
> Markus
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
Markus,
It sounds like the crash (that you are seeing) may be the result of one
of the calculations performed on the dataset.  When data is loaded
things like vertical exxageration, etc are caculated from the data.
As you noted above, it obviously does not like like having any data
(NULL) to load. This problem could probably be tracked down and caught
before it crashes.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
