[GRASS5] [bug #754] (grass) zlib not found
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jun 15 12:24:29 EDT 2001
Hi Rafael,
On Fri, Jun 15, 2001 at 12:12:28AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=754
> Subject: zlib not found
> Platform: Linux/Intel
> Linux distro: RedHat
> linux cpu: Intel (i486, i586, pentium ...)
> Xwindows version: Xfree 4.0.x
> Xwindows manager: KDE 1.x
> TclTk version: I don't know
> grass downloaded at: Hannover site
> grass binary for platform: Linux/Intel binaries
> grass sources source: yes, I am using the latest GRASS from CVS
> I am a first time grass user and I have experienced some problems installing it. When I run the ./configure command, the following message appears:
> could not find zlib (or something like that)
> However, the zlib is correctly installed in the /usr/lib dir
please try to use the configure path parameters:
configure --help |grep zlib
--with-zlib-includes=DIR
Specify includes directory for zlib
--with-zlib-libs=DIR
Specify library directory for zlib
both libz and zlib.h must be present.
Regards
Markus Neteler
