[GRASS5] broken links in documentation and s.vol.rst
Helena Mitasova hmitaso at unity.ncsu.edu
Tue Jun 19 12:37:29 EDT 2001
Markus,
maybe you can replace the outdated command list reference on grass
manual page with Eric's list - it is really useful both for new and
old users.
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/grass_commandlist.html
And here are the broken links
http://www.geog.uni-hannover.de/grass/grass5/related/README.mesa3d
(this link is called from
http://www.geog.uni-hannover.de/grass/grass5/binary/linux/REQUIREMENTS.html
several links:
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/programming/time/index.html
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/programming/sites-api/index.html
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/programming/raster/fpnv.html
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/programming/g3d/index.html
called from
http://www.geog.uni-hannover.de/grass/grass5/index.html
Also please update:
http://www.geog.uni-hannover.de/grass/grid3d/index.html
it has a link to s.vol.rst binaries and says that sources won't be
distributed.
As for s.vol.rst - it may actually be useful to include it into GRASS5 - it
can be run
without the grid3 if it is run with the option of bivariate interpolation
with additional variable (for example precipitation with influence of
terrain).
We just got a paper accepted about it to TGIS and we say that it is available
in GRASS5, so it would be nice to have it there. It works very well and there
aren't
many programs around that can do that. However, there is a problem with
compilation
without the g3d library so I would have to take out all the volume stuff and
we
may end up again with 2 versions of similar program. So I don't know, let me
know
what do you think.
Figure 4b and a related animation in the document
http://www2.gis.uiuc.edu:2280/modviz/viz/sinter.html
and
http://www2.gis.uiuc.edu:2280/modviz/viz/tropy.html
illustrates what the program does The input is 2D raster of elevation and site
precipitation
and output is precipitation raster map. It can be used also for other
phenomena.
Helena
Markus Neteler wrote:
> On Wed, Jun 06, 2001 at 04:15:50AM +0100, Glynn Clements wrote:
> > Anyway, all of this is moot unless g3d finds its way back into the
> > source tree.
> > So, should I get rid of the GLw checks altogether? Or is g3d's absence
> > likely to be only temporary?
> Glynn,
> this g3d absence *is* only temporary unless the bugs are fixed. Jaro
> Hofierka offered to look into them, probably he will find the time.
> Or, Helena, could you provide some help?
> Basic bug is the 3D coordinates system confusion: The 3D coordinates system
> should be similar to GRASS 2D, just with a 3rd dimension. At time some
> modules read bottom-up, other top-down etc. Maybe much of the problems
> can be cleaned out without too much work, only someone has to fully
> understand the g3d concept.
> Markus
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
