[GRASS5] Re: tcltkgrass on cygwin [was Re: installation/compiling instruction for GRASS on cygwin]
John Huddleston jhudd at lamar.colostate.edu
Tue Mar 27 13:44:37 EST 2001
Markus, Andreas, (Grass5)
OK, yes I will do a bindist, plus, this next build is not ipc
but rather sockets.
The perl is in the standard spot, Markus; rather it is the
.tar.gz from Cygwin that is under the contrib area.  So,
do not look for any binaries under /usr/contrib, that is
not where they are located.  They are under C:\bin and
C:\lib and the Cygwin has mounts /usr/bin and /usr/lib
to these areas respectively.
Markus, are you referring to the HTML documents in
the CVS?
John Huddleston
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: "John Huddleston" <jhudd at lamar.colostate.edu>; "Andreas Lange"
<Andreas.Lange at Rhein-Main.de>
Sent: Tuesday, March 27, 2001 1:11 AM
Subject: Re: tcltkgrass on cygwin [was Re: installation/compiling
> Hi John and Andreas,
> currently we have some package name confusion :-)
<snip>
> John, do you intend to use the
> make bindist
> for the next version (hope that this is feasible!)? Then the
> package name would be compliant to the other precompiled
> binaries.
> And John: Shall I store your updated version in CVS? Or shall I
> leave this to you?
>  Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
