[GRASS5] Recommended tweak for 5.1
Rich Shepard
rshepard at appl-ecosys.com
Tue Mar 27 13:18:14 EST 2001
On Tue, 27 Mar 2001, Helena wrote:
> I am not sure whether I understand this correctly but I think that the
> preferable behavior is that if just a name of this non-GRASS file is
> provided (e.g. in s.in.ascii, r.in.ascii etc.) GRASS looks for it into the
> current directory, full path is needed only if it is located in a
> different directory. I too prefer to keep non-GRASS files outside GRASS
> database, but this issue is irrelevant to where those files are.
Helena,
It is just the opposite. The full path is needed regardless of where the
data files are located. And this is not documented anywhere.
> So if I understand it correctly he just asks that e.g. m.in.e00 behaves
> like r.in.ascii or s.in.ascii. I hope I have it right.
Looks good to me.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
