[GRASS5] Recommended tweak for 5.1
Markus Neteler neteler at geog.uni-hannover.de
Tue Mar 27 14:07:35 EST 2001
On Tue, Mar 27, 2001 at 10:18:14AM -0800, Rich Shepard wrote:
> On Tue, 27 Mar 2001, Helena wrote:
> > I am not sure whether I understand this correctly but I think that the
> > preferable behavior is that if just a name of this non-GRASS file is
> > provided (e.g. in s.in.ascii, r.in.ascii etc.) GRASS looks for it into the
> > current directory, full path is needed only if it is located in a
> > different directory. I too prefer to keep non-GRASS files outside GRASS
> > database, but this issue is irrelevant to where those files are.
> Helena,
>   It is just the opposite. The full path is needed regardless of where the
> data files are located. And this is not documented anywhere.
Rich,
this point I don't get. I can easily import data from the local directory.
Say, I have
supermap.asc in $HOME.
Then I
  cd $HOME
  r.in.arc in=supermap.asc out=supermap
ready. Actually I can't see the problem (except that I don't like the
behaviour of v.in.dxf and v.in.arc which read from $LOCATION/arc and
$LOCATION/dxf).
> > So if I understand it correctly he just asks that e.g. m.in.e00 behaves
> > like r.in.ascii or s.in.ascii. I hope I have it right.
>   Looks good to me.
Maybe you could send the command copy-pasted so that we get your
problem?
Thanks in advance,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
