[GRASS5] Proposed process for GRASS reorganization (please read)
strobe anarkhos
anarkhos at mac.com
Fri Mar 23 14:55:40 EST 2001
>Hi Roger and everyone,
>First, I totally trust Markus' hands on 5.x. He's the team leader and will
>always be. The 5.x buck stops with him. I'm reading over the proposal as
>well. I've been putting pen to paper on many different aspects and will share
>a sort of "dream list" soon. Roger hits the nail on the head with the old code
>and the idea of a major revision.
>I propose this: We will go ahead and start a GRASS 6 forum. We'll get that setup
If we want to continue calling it GRASS that's a good idea.
If we implement this 6 will be radically different than 1-5. It would be a fresh start (which from what I've seen is a little overdue).
>in short order and start the process on a server here. I agree it's a large
>undertaking
>and should be the next MAJOR revision. Plus, there are many good things
>that Markus and crew have planned and in the works for 5.1. I say we let
>those things run full circle. I know it's a big temptation to run headlong into
>a new major revision, but we need to be realistic and look farther down the
>road than the next one or two years. Stability is the key. We need time for the
>5.x to saturate the user community out there. That will build a good soild user
>base from which to build. Markus is on track to stabilize 5.0 and move to
>advancing
>5.1 and other 5.x versions should they be applicable. That will take some time.
>But during that time, we are doing the planning and developing for the next MAJOR
>revision... GRASS 6. For the meantime, there's still plenty of work to be done
>with
>5.x. Changing directions in midstream on 5.x would be counterproductive.
In no way did I want to imply this proposal is directly related to GRASS 5 efforts, but what other forum could I bring it up?
Obviously this doesn't effect current GRASS 5 efforts. Perhaps I should have made that clear from the beginning.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
