[GRASS5] g.html2man: perl location problem
Markus Neteler
neteler at geog.uni-hannover.de
Thu Mar 1 14:06:39 EST 2001
Hi Justin,
thanks for your suggestion:
On Thu, Mar 01, 2001 at 04:45:07PM +0700, Justin Hickey wrote:
> > as the path to "perl" is hardcoded in
> > src/scripts/contrib/g.html2man/g.html2man
> Yes, perl has a similar method. The following is from the "Programming
> Perl" book:
> #!/bin/sh -- #perl, to stop looping
> eval 'exec /usr/bin/perl -S $0 ${1+"$@"}'
> if 0;
> .. rest of perl script ...
> It's strange but it seems to work for me. In this case you simply
> substitute maybe $GRASS_PERL for /usr/bin/perl.
Looks funny! However, the "--" is not supported here:
g.html2man
sh: -- #perl, to stop looping: unrecognized option
Usage: sh [GNU long option] [option] ...
sh [GNU long option] [option] script-file ...
And also not the -S:
export GRASS_PERL=/usr/bin/perl
g.html2man
/bin/sh: -S: unrecognized option
Shall I simply remove these flags?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
