[GRASS5] Re: Terminal Errors
Jeshua Lacock jeshua at SierraMaps.com
Thu May 17 22:51:52 EDT 2001
On Thursday, May 17, 2001, at 06:45 PM, Glynn Clements wrote:
> Try setting TERMCAP and/or TERMPATH to /usr/share/misc/termcap, e.g.
> 	TERMCAP=/usr/share/misc/termcap
> 	export TERMCAP
> for Bourne shell or
> 	setenv TERMCAP /usr/share/misc/termcap
> for C shell.
Thanks Glynn,
I tried your suggestions to no avail.
Note that within the X-Windows environment if I type "xterm", it
launches a new terminal window.  If I am in the Mac OS X "Aqua"
environment and type "vt100", it says command not found.
It seems to me that there is a tricky yet simple reason behind this
whole terminal problem.
Any other suggestions?  Would you like to see my "env"?  My (default)
TERMCAP environment variable is about two hundred weird characters.
Thanks again,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
