[GRASS5] Problem with r.fill.dir
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon May 14 03:00:37 EDT 2001
Hi Roger
"Roger S. Miller" wrote:
> Thanks for the pointer. The direct solution here is to remove the
> line that includes error.h. I thought I did that before the copy
> went to CVS, but I guess I didn't. <error.h> was originally included
> to check on a condition that never occured, so I removed the check.
> <error.h> isn't needed in the current version.
It compiles fine on SGI's now.
> The code is written to use open, read, write, and lseek, (all POSIX)
> and I don't think I can switch lseek to fseek (ANSI) without changing
> all the other references to their ANSI counterparts. If there are
> ongoing problems, then I'll do it, but then the same change will be
> needed in a lot of the rest of the GRASS code.
Sorry, it was my problem here. It's been a while since I wrote low-level
I/O programs and I did not recognize lseek. I thought that the use of
lseek required the inclusion of a non-standard header file (error.h),
so, I looked it up in my C book which does not mention POSIX and as a
result, made my suggestion in my previous mail. However, since it is
POSIX I retract my original suggestion.
Thanks for the fix.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
