[GRASS5] i.composite problems verified
Eric G. Miller egm2 at jps.net
Tue May 1 02:43:20 EDT 2001
On Mon, Apr 30, 2001 at 03:58:49AM +0100, Glynn Clements wrote:
> I've also added "r.out.ppm3", which creates a PPM image from red,
> green and blue map layers.
> The main components which are still missing[1] are RGB versions of the
> "raster" command for p.map and ps.map. I'll look into ps.map next.
> The paint system seems to only support paletted raster data, and only
> 256 colours at that. Is it still in widespread use? There aren't many
> drivers (13, or 9 if you exclude NULL, ppm, preview and preview2).
> Wouldn't it be better to scrap "paint" and just point people at
> Ghostscript? Any updates to the paint architecture would presumably
> require developers who have access to the technical specs of all of
> these printers (or, at least, all of the ones which would still work
> after an interface change).
I'd vote for scrapping the "paint" routines and putting efforts into
ps.map.  But maybe it'd be good to poll the user community first...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
