[GRASS5] libgrass5 1.0.0 release
Fri Nov 2 15:10:43 EST 2001
Folks,
I have prepared a 1.0.0 release of libgrass.  The most noteworthy change
in this release is support for the new (LZW-free) compression format for
GRASS rasters incorporated into GRASS roughly 8 months ago.  Note that old
compressed rasters will nolonger be readable.
The library is also updated to mostly current code from libgis.
General info:
   http://gdal.velocet.ca/projects/grass
Direct download:
   http://gdal.velocet.ca/projects/grass/libgrass5-1.0.0.tar.gz
Amoung other things, libgrass is used by OSSIM and GDAL to get access to
GRASS databases.
Best regards,
