[GRASS5] Bugracker
Bernhard Reiter bernhard at intevation.de
Fri Nov 9 11:34:29 EST 2001
On Fri, Nov 09, 2001 at 05:22:27PM +0100, Bernhard Reiter wrote:
> On Fri, Nov 09, 2001 at 03:05:43PM +0100, Andreas Lange wrote:
> > The RT is populated with some bugs which are not related to GRASS, but
> > to broken linux installations. I will generally help, but often it is
> > not possible to reproduce the bug.
> Very true.
> > Time is a very scarce ressource, so i want change to resolved.
> We should close bugs which are obviously not related to GRASS even sooner.
Another remark:
The bugtracker in fact helps us to save time as more than one person
can pick up the status of a bug and progress it.
If several bugs are seen to be related to GRASS, though they are not
it is good if people find this documented in the bugtracker
and start to search for the solution in the right places.
	Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20011109/5ed2a562/attachment.bin
