[GRASS5] v.to.sites question
Markus Neteler
neteler at itc.it
Mon Nov 19 10:53:59 EST 2001
today I tried to generate a sites file from a vector map
(containing a circle). However, the result was not what
I expect from the man page:
"If -a flag is selected,
v.to.sites extracts all vertices from a vector file, if not selected,
it extracts site (point) features only, ignoring lines and areas. If
-i flag is selected then, for each line, if the distance between any
two vertices on this line is greater that dmax, additional points are
added to keep the distance withing dmax range."
I thought that lots of sites are generated along the vector lines (that's
what I need). Am I wrong in my assumption? Is it a bug or a feature...?
Best regards
Markus
