[GRASS5] v.to.sites question
Radim Blazek radim.blazek at dhv.cz
Mon Nov 19 11:19:57 EST 2001
On Mon 19. November 2001 16:53, Markus Neteler wrote:
> Hi,
> today I tried to generate a sites file from a vector map
> (containing a circle). However, the result was not what
> I expect from the man page:
>   "If -a flag is selected,
>    v.to.sites  extracts all vertices from a vector file, if not selected,
>    it  extracts  site (point) features only, ignoring lines and areas. If
>    -i  flag  is selected then, for each line, if the distance between any
>    two  vertices on this line is greater that dmax, additional points are
>    added to keep the distance withing dmax range."
> I thought that lots of sites are generated along the vector lines (that's
> what I need). Am I wrong in my assumption? Is it a bug or a feature...?
It seems to work with labeled lines.
Radim
> Best regards
>  Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
