[GRASS5] Which colors are right?
Eric G. Miller
egm2 at jps.net
Tue Nov 20 23:36:49 EST 2001
On Tue, 20 Nov 2001 19:44:50 -0800
"Eric G. Miller" <egm2 at jps.net> wrote:
> So, I was looking at fixing that d.area dig_list problem, when I found
> the current sources don't compile. Amongst the rubble was the redefinition
> of all the defined colors in colors.h and vect/dig_defines.h -- and the
> definitions don't match! How this could be the case for so long and
> not cause an error, I don't know. But, the GRASS standard color defines
> should only live in one place. I'm voting to drop the definitions in
> dig_defines and have it include colors.h. But, I don't yet know the
> ramifications of doing so...
As follow-up, I made a few modifications to colors.h and vect/dig_defines.h
and so far it looks okay. I'm updating my CVS and will do a rebuild followed
by some other checks. At least v.digit seemed to get color numbers by
string name, so it seems okay...
Eric G. Miller <egm2 at jps.net>
