[GRASS5] releasebranch - help
Bernhard Reiter bernhard at intevation.de
Sun Sep 16 19:05:40 EDT 2001
The viewcvs web interface shows all tags and the MAIN trunk first.
This is correct behaviours. People should know CVS a bit to make use
of all information of viewcvs.
We have to explain it to the rest interested.
	Bernhard
On Wed, Sep 12, 2001 at 02:44:28PM +0200, Markus Neteler wrote:
> Hi Radim,
> On Wed, Sep 12, 2001 at 02:39:27PM +0200, Radim Blazek wrote:
> > Hi,
> > I wanted to fix one bug in ps.map (src/ps.map/ps.map/cmd/ps_area.c).
> > In default/devel branch everything seems to be OK. In release branch (?)
> > which is tagged here: Treleasebranch_11_april_2001_5_0_0
> > (cmd/CVS/Tag) I had run:
> > cvs commit -m "shift set to 0 for non LL" ps_area.c
> > Checking in ps_area.c;
> > /grassrepository/grass/src/ps.map/ps.map/cmd/ps_area.c,v  <--  ps_area.c
> > new revision: 1.1.4.1; previous revision: 1.1
> > done
> perfect, it reached the right destination.
> > But I cannot check that through cvs-web interface. It is not in
> > any of following tags (branches?):
> > releasebranch_5_0_0
> > releasebranch_500
> > releasebranch_14_august_2001_5_0_0
> > grassreleasebranch_5_0_0
> > I am doing something wrong, could somebody help me?
> Beware of the CVS web interface!! It is looking at the experimental
> branch only [Jan, Bernhard, please either change that or switch it
> off].
> I just checked with
> http://freegis.org/cgi-bin/viewcvs.cgi/grass/src/raster/r.info/cmd/
> which I changed two days ago. The change doesn't appear in CVS web,
> but is in the right place.
> -> don't use and trust the web interface!
> > I know, I am bit late in bugfixing in release branch, but it is important
> > bug and I had no time (and I have no time) for grass in last moths.
> Hope to know you back soon :-)
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Professional Service around Free Software                (intevation.net)
The FreeGIS Project                                         (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010917/b057a0ae/attachment.bin
