[GRASS5] [bug #805] (grass) r.in.gdal: satellite image import - POINTS file wrong
Request Tracker grass-bugs at intevation.de
Thu Sep 20 06:31:10 EDT 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=805
Subject: r.in.gdal: satellite image import - POINTS file wrong
grass downloaded at: CVS Server, Germany
grass sources source: yes, I am using the latest GRASS from CVS
Hi again,
another bug: r.in.gdal generates a group/POINTS file in case of
GCPs present in imported satellite images (a great feature!).
However, the xy-coordinates don't match the current region, they
are negative. Frank, you fixed that recently,
but it is not yet uploaded to CVS...
Just to record this remaining problem,
Thank in advance,
 Markus
-------------------------------------------- Managed by Request Tracker
