[GRASS5] configure on cygwin, freebsd, solaris, irix
Glynn Clements
glynn.clements at virgin.net
Fri Sep 21 15:27:43 EDT 2001
Andreas Lange wrote:
> I don't think that it is a good idea to make blas and lapack not found
> an error in configure, as these libraries are not used. Or there should
> be a hint in the documentation that --enable-blas=no and
> --enable-lapack=no must be set.
I'll default these two options to "no".
Glynn Clements <glynn.clements at virgin.net>
