[GRASS5] raster file history question
Markus Neteler neteler at itc.it
Thu Apr 4 07:10:48 EST 2002
On Thu, Apr 04, 2002 at 12:32:19PM +0200, Bernhard Reiter wrote:
> On Wed, Apr 03, 2002 at 06:29:37PM +0200, Markus Neteler wrote:
> > for a few modules I would like to add the feature that
> > the invoking command lines is stored into the raster file history.
> > It will be trivial, but I don't get the command line into
> > a string.
> Maybe it is just me, but I don't understand the question.
Ok, sorry for boing unclear. A new try:
I want to store the command line, which was used to start a
module, into the history section of data.
Example: I run
r.proj dgm1km loc=europa map=europa
When I now run
 r.info dgm1km
the string "r.proj dgm1km loc=europa map=europa" should appear in
the history. This is implemented in r.slope.aspect and s.surf.rst,
but more complicated there. For my module (not r.proj) the command line
string is sufficient to later remember the parameters which I used to
generate that particular map.
It must be something with argv[] or so.
Thanks,
 Markus
