[GRASS5] raster file history question
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Apr 4 08:49:08 EST 2002
Markus Neteler wrote:
> Ok, sorry for boing unclear. A new try:
> I want to store the command line, which was used to start a
> module, into the history section of data.
> Example: I run
> r.proj dgm1km loc=europa map=europa
> When I now run
>  r.info dgm1km
> the string "r.proj dgm1km loc=europa map=europa" should appear in
> the history. This is implemented in r.slope.aspect and s.surf.rst,
> but more complicated there. For my module (not r.proj) the command line
> string is sufficient to later remember the parameters which I used to
> generate that particular map.
> It must be something with argv[] or so.
what about G_recreate_command()? IMHO this gives a complete command
line, even if the command was invoked interactively.
I think that a own library for accessing and creating metadata (history
data) would be very useful. Somehow the metadata capabilites should be
unified for all modules (raster, vector, sites).
HTH,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.lycos.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
