[GRASS5] raster file history question
Markus Neteler
neteler at itc.it
Thu Apr 4 11:28:36 EST 2002
On Thu, Apr 04, 2002 at 03:49:08PM +0200, Andreas Lange wrote:
> Hi,
> Markus Neteler wrote:
> > Ok, sorry for boing unclear. A new try:
> > I want to store the command line, which was used to start a
> > module, into the history section of data.
> > Example: I run
> > r.proj dgm1km loc=europa map=europa
> > When I now run
> > r.info dgm1km
> > the string "r.proj dgm1km loc=europa map=europa" should appear in
> > the history. This is implemented in r.slope.aspect and s.surf.rst,
> > but more complicated there. For my module (not r.proj) the command line
> > string is sufficient to later remember the parameters which I used to
> > generate that particular map.
> > It must be something with argv[] or so.
> what about G_recreate_command()? IMHO this gives a complete command
> line, even if the command was invoked interactively.
yes - this will be the command I was looking for. Thanks for the pointer.
> I think that a own library for accessing and creating metadata (history
> data) would be very useful. Somehow the metadata capabilites should be
> unified for all modules (raster, vector, sites).
Oh yes - that's really needed! On FreeGIS mailing list is currently some
discussion about that, see
http://intevation.de/pipermail/freegis-list/
However, even a simple solution might be better than what's currently
implemented. At least the data import modules should take more care about
that (eventually optionally ask the user about data source, year etc).
Markus
