[GRASS5] Release Management (10 days to go before Freeze)
Bernhard Reiter bernhard at intevation.de
Mon Apr 15 06:00:25 EDT 2002
On Sat, Apr 13, 2002 at 06:47:46PM +0100, Glynn Clements wrote:
> Bernhard Reiter wrote:
> > Great! I declare Glynn GRASS programmer of the week! :)
> That was easy ;) I didn't say that I fixed them, just that I closed
> the RT entries.
Well you did follow up on all this
and continued working on it.
But you are right: Everybody can become GRASS programmer of the week!
		   Just help with a couple of bugs!
> OTOH, after fixing #809, I found another bug in s.in.shape, ...
> Upon fixing that, I noticed a further bug,
> ... and found a bug in r.topmodel
> So that's three unreported bugs fixed as well.
Good work. Hard to squash all that small little bugs.
> So, we're down to 20 open bugs. Of those, half are v.* or i.* programs
> (which I'm not at all familiar with), and the rest are cases where I
> either don't understand the problem, or can't reproduce it.
You should ask bach the bug reporters on unreproducable problems.
If they stay unreproducable, they are bound to be closed.
> #873	monitor resizing does not work on SOlaris/X11R6.4
> which will probably be resolved by the removal of the resize/redraw
> code. For more fundamental reasons than #873, which is just due to
> some WMs not liking the the WM_NORMAL_HINTS setting.
> Basically, a command which works when run by the user from the shell
> won't necessarily work (or produce the same result) when run by the
> monitor. Particularly if the session handling gets changed in any way.
Can be make this code conditional and add a --solaris-resize-fix
to the configure? AFAIK this would please everybody, right?
	Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020415/5a7ec023/attachment.bin
