[GRASS5] Shared Libraries
Markus Neteler
neteler at itc.it
Sun Apr 21 10:28:58 EDT 2002
On Sun, Apr 21, 2002 at 10:41:27AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > FWIW, it's now possible to build GRASS on Linux with most of the main
> > > libraries as shared libraries. Brief instructions are in mk/README.
> > Glynn,
> > just curious: Is there a way to allow for individual compiles with
> > make? E.g.
> > src/libes/proj > make
> > makefile:2: head.mk: File or directory not found
> > makefile:60: tail.mk: File or directory not found
> > make: *** No rule to make target 'tail.mk'. Stop.
> See the "gmake5" script which is created during the build process (or
> by "make gmake".
Yes - but then I receive again a static library, right?
> > Perhaps the full path could be written from
> > mk/mkmakefiles
> > Before breaking anything, I would like to ask.
> The problem is that the makefiles need vars.mk (which is basically the
> "head" file), which lives in the build directory. But the makefiles
> generated by "make makefiles" or "mk/mkmakefiles" aren't specific to a
> particular configuration, so they can't reference the build directory.
Ah, ok. So I'll recompile from the top directory.
No problem,
Markus
