[GRASS5] documentation
Bernhard Reiter bernhard at intevation.de
Tue Apr 30 08:19:41 EDT 2002
Hi Moritz,
sounds like a plan.
On Tue, Apr 30, 2002 at 01:14:53PM +0200, Moritz Lennert wrote:
> The French list is very actively preparing work on documentation.
Say hi to all the French people! :)
> As we've discussed here as well, docbook-xml seems a good
> solution. Someone suggested getxml (gettext for xml) for
> internationalization. I don't know getxml, yet, so I'll have to
> look into that, but if we could get some gettext functionality
> that would be great.
I did not dig into that question.
As long as we end up with a transparent Free Software solution, it's fine.
> Another question that came up: should we create a 'documentation'
> repository in cvs ? At the moment, there is one for the French
> side, but maybe a centralized repository would be better. And I
> believe that it should be seperate from the grass source tree in
> order not to complicate issues of release branching etc.
If you think such a module would be useful, let me know.
You are probably a better person to judge this.
Please make a suggestion for the name of the CVS module then.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020430/c4d16d18/attachment.bin
