[GRASS5] compiling GRASS5 cvs
Bernhard Reiter bernhard at intevation.de
Thu Aug 8 15:02:18 EDT 2002
John,
please note that the CVS version are development versions mostly
for developers. It takes a significant amount of time to teach
someone to be a developer.
If you are a beginner to GRASS5 I suggest that you start trying
the release code base and see how it works out for you,
which currently is
	grass5.0.0pre5
Note that this contains nviz which is an opengl application
for visualisation.
On Thu, Aug 08, 2002 at 10:35:42AM -0700, John Vo wrote:
> First of all, I am a beginner with using UNIX and GRASS5. I have
> downloaded the GRASS5 CVS because I would like to work with the 3D
> visualization environment. My system is Windows 2000 and using the CYGWIN
> emulator. Basically I am having problems with the installation of GRASS5.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020808/e4171eec/attachment.bin
