[GRASS5] [bug #911] (grass) make Grass51 on Solaris8
Wallace, Beverly T beverly.t.wallace at lmco.com
Thu Feb 7 19:29:29 EST 2002
Thanks for the quick responses.  I installed the GNU make and tar as
suggested.  When I use the GNU make (/usr/local/bin/make), I get
the same error message about Rules.make line 9.
I will install the experimental version of GRASS and try again.
> -----Original Message-----
> From:	Markus Neteler [SMTP:neteler at itc.it]
> Sent:	Thursday, February 07, 2002 1:13 PM
> To:	Request Tracker
> Cc:	grass5 at grass.itc.it
> Subject:	Re: [GRASS5] [bug #911] (grass) make Grass51 on Solaris8
> On Thu, Feb 07, 2002 at 09:33:15PM +0100, Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=911
> > Subject: make Grass51 on Solaris8
> > Platform: Sun Solaris 8
> > grass downloaded at: Trento site
> > grass binary for platform: I compiled the sources myself
> > grass sources source: yes, I am using the latest GRASS from CVS, 2/7
> snapshot
> > c compiler name: gcc
> > I am using the 2/7/02 snapshot of grass51 with grass5.0 pre3.  My
> commands are indented:
> > 	cd /leo2/Grass5/pre3/grass51
> > 	./configure --with-grass50=/leo2/Grass5/pre3/grass
> ... this can't work because GRASS 5.1 needs the *experimental* version,
> not the preX. Means that you have to extract the CVS HEAD version
> from GRASS.
> Radim, we discussed the "make copymix" target. Will it solve the
> problem when I update the grass51-snapshot script to run "make copymix"
> to get a 5.1 version with required 5.0 code merged into?
> Then: As Bernhard says: Please install the gnu make (and also gnu tar)
> on your SUN. Especially the original tar from SUN is worst case stuff.
> Cheers
>  Markus
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
