[GRASS5] nviz / tcl compile problem
Bernhard Reiter bernhard at intevation.de
Wed Feb 13 15:28:17 EST 2002
On Wed, Feb 13, 2002 at 08:00:51PM +0000, Glynn Clements wrote:
> The problem is specific to creating new Tk widgets; this requires the
> "internal" headers, while other uses of Tk only require tk.h.
> Basically, the Tk packages available from Linux distribution vendors
> don't usually include the header files which are necessary for
> creating new widgets.
> The only options for NVIZ are to either:
> 1. Require a working Tk development environment, including TkInt.h
> etc; this will typically require the user to build Tk from source.
Or at least get the right sources.
> 2. Supply the missing files for all common versions of Tk.
Then 1. is the better choice in my views.
And tell the tcl/tk people and package maintainers about the problem.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020213/7f712a03/attachment.bin
