[GRASS5] probs with .dxf import
Heiko Kehlenbrink
heiko.kehlenbrink at vermes.fh-oldenburg.de
Fri Feb 15 13:46:13 EST 2002
Roger Miller wrote:
>On Fri, 15 Feb 2002, Heiko Kehlenbrink wrote:
>>Hi all,
>>got probs (again) importing a .dxf file into GRASS.
>>I was trying to import a file called sample.dxf wich i loaded
>>down from www.english-nature.org.uk/pubs/gis/more.htm
>Heiko,
>I think you found a bug. I set up a location with the specifications you
>provided and v.in.dxf failed for me as it did for you. I then managed to
>import the same dxf file (Sample.dxf) into two other applications without
>trouble. Then I extracted the VERTEX data from Sample.dxf file and
>converted that to a dig_ascii file and read that in. That worked and
>displayed within the window that you specified.
>The dxf file consists of three POLYLINE objects, which in my experience
>are little-used; the LWPOLYLINE is more common. I think you came across a
>problem with v.in.dxf and POLYLINE objects.
>Unfortunately, that doesn't help with your problem.
>Roger Miller
>_______________________________________________
>grass5 mailing list
>grass5 at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grass5
Well Roger,
thank you for spending time on it.
Will you send a bug report to th bug tracker?
Btw what applications do you use for xtracting the VERTEX data?
Will you pour ma a favour and send me the dig_ascii files you made?
Is it possible that the Sample.dxf is a diffrent (maybe newer)
.dxf-version than GRASS could deal with?
have a nice weekend
Heiko Kehlenbrink
