[GRASS5] Re: Grass GUI
Radim Blazek
radim.blazek at wo.cz
Wed Feb 20 19:12:57 EST 2002
On Tuesday 19 February 2002 12:26, M Lennert wrote:
> Sorry, that wasn't clear. When I add a vector area map (having changed the
> script to use d.vect.area instead of d.area), I can then chose the
> fillcolor and the linecolor. When I click on the color button, I can either
> chose any standard Grass color or I can click on a color palette button
> which allows me to customize RGB colors. When I do the latter, and then
> launch the 'display' in d.dm's main window, I can see that the command
> issued is
> d.vect.area mapname fillcolor=grey linecolor=grey
> instead of
> d.vect.area mapname fillcolor=r:g:b linecolor=r:g:b
d.dm was written before r:g:b color was available.
Radim
Radim Blazek
Praga, Bohemia
