[GRASS5] dalloc.c, svd.c ?? linked list code ??
Glynn Clements glynn.clements at virgin.net
Sun Feb 24 00:17:14 EST 2002
Eric G. Miller wrote:
> 1) Anybody know anything about dalloc.c and svd.c in the gis library?
> Seems the dalloc.c functions should be documented with the other memory
> management routines.  I don't know what svd.c is about.  There are
> virtually no comments in the code, nothing in the programming manual
> that I could find.  It'd be good to get these items documented.
FWIW, the functions in svd.c are used by m.svfit, which has the
description:
       m.svfit - Semivariogram model fitting.
Both svd.c and dalloc.c appear to overlap with the plans for the gmath
library.
Glynn Clements <glynn.clements at virgin.net>
