[GRASS5] GRASS internationalization
Glynn Clements glynn.clements at virgin.net
Tue Feb 26 17:06:39 EST 2002
Markus Neteler wrote:
> As far as I see the current number of continous contributors I
> even see problems to keep three trunks (5.0exp, 5.0release, 5.1exp).
> We probably do not have the human resources at time to manage such a
> huge code base like this. Up to now we didn't reach the number of
> contributors as found for KDE or Linux kernel projects. Of course...
> Anyway, the 'to branch or not to branch' has been discussed enough.
> Point is that we obviously don't get fixed the 5.0 bugs in a reasonable
> time frame. From that we have to draw conclusions about the threshold of
> critical and non-critical bugs.
One potential criterion for categorising bugs: was the bug present in
the release version of GRASS 4.3? If it was, then I can't see any
reason why it needs to delay the release of 5.0.
As for the RT, there appear to be a significant number of non-bugs and
maybe-or-maybe-not-bugs in there. If a bug isn't readily reproducible
from the information which is contained in the bug report, the chances
of anyone being able to fix it aren't good.
Glynn Clements <glynn.clements at virgin.net>
