[GRASS5] Want GNU libavl ?
David D Gray
ddgray at armadce.demon.co.uk
Tue Jan 22 15:55:02 EST 2002
Eric G. Miller wrote:
>>On Mon, 21 Jan 2002 22:39:07 +0000, David D Gray
>><ddgray at armadce.demon.co.uk> wrote:
>>>could be used, coming from more different plances (which may lead to
>>>more
>>>confusion, at least in principle...)
>>>Is there anyone who is aware of a usable (GPL'd, LGPL'd) container
>>>library for the C programming language?
>>I know that we have this long-standing policy of preferring ANSI C as
>>the central language for GRASS. But the truth is that few people _if
>>any_ today in engineering, research, academia use C as the
development >>language. It is almost universally C++ that is used. I
think that we >>have to accept that now and move on. We don't need to
necessarily code >>the core of GRASS in C++, but we should be able to
wrap in external >>data structures if these are only available (or the
best >>implementations are available ) in C++. Also reflect : Mitab,
Dime ... >>the list goes on.
>I think it's mostly a matter of pragmatism. ANSI/ISO C89 works well
>pretty
>much everywhere. Also, GRASS has a lot of code. Do you want to >rewrite
>it all? One problem with C++, it's a one-way street. Sure, you can
>write
>C that is C++ friendly, but the reverse is difficult. That a lot of
>other
>folks are primarily using C++ for relatively new projects doesn't have
>a lot of bearing, when you consider maintaining/enhancing an existing
>code base written in C.
I'm certainly not advocating C++ for standard developer use. It's just
that much functionality is more available (by a large order) in C++
libraries than in C. If it could enhance the functionality of GRASS,
even if felt by many to be an uncomfortable add-on, then is it not worth
at least considering. But as it is poorly portable (at least STL) [and
Glynn has also pointed this out], maybe it is not useful in this instance.
>>>The only container library I'm aware of are for the C++ programming
>>>language,
>>>the STL provided with libstdc++, the container library of the
>>>WxWindows framework (based on macros rather than on templates) and
>>>STLPort (www.stlport.org, not sure about the license, anyway it's
>>>still
>>>an STL implementation...).
>>One of the things that's really lame about C++ is the poor general
>>support for some of it's features - core features in my view - like
>>exceptions and STL across the range of platforms. So much so that
even >>it's advocates generally recommend coding without relying on
these >>features. But it gets a bit of a headache when you create whole
>>development systems as a dependency for anyone who wants to build
>>GRASS if we choose to use implementations from other languages (like
>>Ada/Gnat).
>Well, if I had a choice between C++ and Ada95, I'd probably choose the
>latter. C++ keeps all the dangerous stuff of C and adds new ways to
>shoot yourself in the foot. I don't see requiring GNAT as >fundamentally
>different than requiring bison. BTW, Ada should be supported in GCC >3.1,
>as ACT donated their public GNAT to the GCC team. I hope the GCC folks
>give it due attention.
I would (and do) prefer Ada95 also. But is it really that portable?
True, GNAT is portable, but few (no?) other Ada compilers are complete
.. they're like a box of chocolates... A large problem is resolved if
GNAT becomes effectively a part of gcc, but how many people compile
GRASS with something other than gcc?
David
